Perform this procedure to configure remote IS-IS Multi-area SPB nickname for a specific SPBM instance on the switch.
  1. Enter IS-IS Router Remote Configuration mode:
    enable
    configure terminal
    router isis remote
  2. Configure IS-IS Multi-area SPB nickname:
    spbm <1-100> nick-name <x.xx.xx>
Configuring remote IS-IS Multi-area SPB nickname for SPBM instance:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis remote
Switch:1(config-remote)#spbm 4 nick-name 1.11.16
What to do next
To verify the configuration, see Display the Remote IS-IS SPBM Nickname Configuration.
The following table defines parameters for the spbm command.
Variable Value
<1-100>
Specifies the SPBM instance on the remote IS-IS interface.
nick-name<x.xx.xx>
Specifies a nickname for the remote IS-IS SPBM Multi-area SPB instance. The value is 2.5 bytes in the format <x.xx.xx>.
